false rev limiter
Old 02-25-2009 | 08:39 PM
94accordexl's Avatar
Default false rev limiter
i just bought this 98 v6 with a cel on.i had it scanned and it said master malf. egr system. so i cleaned the ENTIRE egr system and ran a fuel system cleaner through it as well(i work at express oil change) i reset the light and drove it home and the light came back on about 2 miles from home. when accelerating it would hit a rev limiter at 3k rpm in drive or park.i also noticed vtec wasnt working and checked and changed the oil and noticed the pressure switch connector was broken off. any ideas whats causing the false rev limiter?is it in limp mode? thanks for any thoughts or advice
Old 02-26-2009 | 07:59 AM
Certain CEL error codes can put it into limp-home mode, but for the V6 I'm not sure which ones can do that. Fix that pressure switch & see...
Old 02-26-2009 | 07:54 PM
thanks for the reply.i put a pressure switch in today out of a 4cyl and reset the cel.so far it runs great
vdub90vw
04-01-2011 08:47 PM
jasonfridlund
09-07-2009 09:30 PM
Driving me nuts
12-01-2008 08:17 PM
jaeal
05-12-2007 12:46 PM
dinzer
10-18-2005 11:27 AM
