Fantastic tool for front brake rotor replacement
#22
![Default](/forum/images/icons/icon1.gif)
Thanks!
#24
Yea, you guys lost me. The original OP - link doesn't work. The J.C. Whitney link doesn't really show anything. What years are we talking about? I have a 95, and know too well...the front rotors are part of the hub assembly. Can someone post a pix. Thanks.
#25
What you need is two M10x1.25x4 inch full threaded bolts. Take two of the hub to rotor bolts out put your new long ones in turn the hub so the long bolts hit vertical on the knuckle and walk the bearing apart...
Easy no need for expensive tools works exactly the same!
I do tend to agree these bearings shouldn't really be apart.... but beating the **** out of the bearing to get it out of that knuckle isn't good for them either this way is much easier!
