First time Honda Owner needs some help
Old 04-10-2012 | 08:48 PM
99accordtampa's Avatar
Default First time Honda Owner needs some help
I bought a 99 Accord EX 4 Cylinder a couple of weeks ago. I realised that it had some issues but the price was fair. So far I have replaced the Battery(last week), and Alternator(today). Also I have A CEL(i think thats what its called) that is P1457(I think I need to replace the Vapor canister). However, the Question that I have is, With my new Alternator installed my car isnt idleing well(it was before). Especially when coming to a stop. I have a Haynes book but it isnt very clear about Idle speed adjustment. Could I have over Tightend the Belt? Please Respond with any suggestions.
Thanks.
Old 04-11-2012 | 06:40 AM
Clean throttle plate (both sides, throttle bore, idle air control valve(IACV), and ports to IACV. I think the throttle body must be removed to access ports on your Accord. Check DIY forum for guidance and check youtube for videos of procedure.
Old 04-11-2012 | 07:02 AM
Thanks TexasHonda,
Ive been looking for a while now. I was hoping i could find a walkthrough or something for this. So far no luck. Ill keep looking and Ill try posting in the DIY Forum.
Old 04-11-2012 | 09:38 AM
crispin's Avatar
Originally Posted by 99accordtampa
Thanks TexasHonda,
The DYI section is only for write-ups on completed projects, not for asking questions.
You can search the DYI section for an answer but please do not ask a question there.
Old 04-12-2012 | 06:50 AM
OK, Thanks.
Old 04-12-2012 | 06:51 AM
What about DIY requests, would that be appropriate?
Old 04-12-2012 | 08:54 AM
No, not "DIY requests". We moderators wish that there wasn't such a board, & we're trying to discourage anyone from posting there. Here in General Tech is where you post questions.
Look in "DIY answers" for a post by me about EVAP leaks. Probably you can search for "P1457". Get that straightened out first. A common failure is the vent-shut valve which should be explained in there.
But if YOUR EVAP failure is the purge valve, then I think it would act like a vacuum leak. A vacuum leak will cause the idle to surge up & down.
Then look in DIY answers for a post by me about setting the BASE idle.
Old 04-12-2012 | 08:52 PM
Default Thanks
Wow! Thanks JimBlake. I guess I wasnt searching for the right things. I think I have what I need to get this problem solved. Im going to fix the EVAP problem ASAP. But your response(with schematic) to darko's Idle Problems Post was exactly what I was looking for. Thank you very much. I will update when I have completed the Throttle body cleaning and Base Idle Set Procedure. It may be two weeks before everything is done.
Thanks again
Eazy
12-28-2012 03:30 PM
Bruce.Chisholm
09-22-2011 12:19 AM
WhiskeySlick
07-31-2011 04:39 AM
kriegz99
06-13-2007 12:31 AM
pbook4g5
12-12-2006 02:54 AM
