folding seat lock
Old 12-16-2011 | 09:25 AM
jimgrms's Avatar
Default folding seat lock
i got my 07 accord sedan used , the ignition key won't open the lock for the rear folding seat. Is there a trick i am missing ? Is there a way to disable this lock so the seat will fold up and down without it ?
Old 12-16-2011 | 10:30 PM
How many keys did you get when you bought the car, does it work everything else on the car? From inside the trunk there is a handle you can pull to get it open.
Do you have an owners manual? If not try this link to download one......
www dot ahm-ownerlink dot com
Old 12-17-2011 | 03:38 PM
posativJ311's Avatar
I have a 07 Accord also. When I try to fold mine down using the key from inside of the car, I have to lean into the seat putting pressure into the seat while turning the key at the same time. That's the way it has always been for me.
Once the key turns then hold it in that spot while pulling the back seat toward you.
Hope this helps you
Pyheme
12-25-2011 01:17 PM
MysticBlueEX
02-18-2011 06:55 AM
galant350z
03-24-2009 05:09 PM
Taimyshu
07-16-2008 11:09 PM
lacrw
08-01-2007 08:43 AM
Quick Reply: folding seat lock
