Front end growl months after new axle replacements
Old 01-15-2008 | 05:26 PM
Alekat's Avatar
Default Front end growl months after new axle replacements
Replaced both front axles w/new units on '87 accord LX 2.0L auto.
All went well with the input of sir_nastyand deserthonda.
Now a few months later am experiencing a low growl in drivetrain, (shift to neutral changes nothing).
Suspect a wheel bearing since axle inboard caliper measurements for depth and diameterwere identical and hubs at transmission seatedadequately with factory installed circle clips. No leakage at seals and all seemed well.
Any thoughts?
Thank You.
Old 01-15-2008 | 08:37 PM
HondatechAV6's Avatar
Default RE: Front end growl months after new axle replacements
did you overtorque the axle nuts?
Old 01-15-2008 | 08:39 PM
andthegood's Avatar
I'd look into the hub bearings a little more. Is it louder when you're turning or is it pretty consistent all the way around?
Old 01-17-2008 | 11:11 AM
Alekat's Avatar
Thanks for the tips.
Does not seem to get louder on turns.
Resettorque, (134 ft lbs).
Will see if it helped.
Old 01-19-2008 | 08:30 PM
cross your fingers, i feel the damage is already done(either from overtorque or just wear)
Old 01-22-2008 | 03:24 AM
YeuEmMaiMai's Avatar
growling is almost wheel bearings how many miles on the car? Here is an easy test, when you are going down the FWY, turn the wheel slightly left to right and if the noise changes, it's the wheel bearings
Old 01-28-2008 | 09:03 PM
Alekat's Avatar
Weather broke today in Omaha.
Checked all the wheel bearings. Fronts were right at the 134 ft lb torque, (assuming the torque wrench was accurate - have always stored it spring tension un-loaded). Rears were very quiet and no excess play, (did notre-adjust rears).
Will road test next few days.
Mileage: 109,000
Thanks guys.
Old 01-28-2008 | 10:21 PM
oma93's Avatar
Wow didn't realize you are in Omaha. I'm in Bellevue. If you ever get really stuck on a problem with your car and need help, let me know.
Old 02-09-2008 | 08:42 PM
Alekat's Avatar
oma93: Thanks for the offer.
The growl is unchanged and has not worsened since installation.
Will listen more closely for changes on turns.
adkant
03-06-2015 05:49 PM
McDesign
11-13-2011 09:59 PM
sthavorn
01-27-2008 08:43 PM
kleptodathief
10-28-2007 05:21 AM
tiberius
10-18-2006 12:51 AM
