Front end issues
Here's a picture of the front suspension, they don't even point out the radius arms in the shop manual. I put a circle around the bushings that are easy to overlook.
The caster adjustment section is only to show the bushings & washers assembled like they are supposed to line up.
I saw that I have the same manual.. I wonder why there is nothing about the replacement of these bushings? How does one even check to see if they are actually shot?
I guess I will keep searching and asking questions until Saturday when I can spend some more quality time under the car.....
Thanks again Guys..
Thanks again Guys..
Not sure why they don't stress those as being part of the front suspension. Check like any other bushing - try to move it around & see if its loose, clunks, squeaks, etc. Check whether the rubber is rotting & cracking?
And don't forget to check the subframe itself like Poorman suggested. I remember a thread where it was corroded below the AC evaporator drain & just about coming apart.
USEDBLACKSTAR
09-12-2012 10:02 PM
