Front subframe beam
Old 08-16-2011 | 09:57 AM
Tek310's Avatar
Default Front subframe beam
The beam that the lower control arms bolt to. Can this be replaced?
Old 08-16-2011 | 12:42 PM
Looks like #2 is what you're talking about?
Old 08-16-2011 | 09:04 PM
g22cd5's Avatar
Supper Moderator
is something wrong with it or you looking for a upgrade? If so ESP makes some really good traction bars check them out. They are fair priced too...
explicitspeedperformance.net/
Old 08-16-2011 | 09:23 PM
Tek310's Avatar
Oops it is the rear section of the front sub frame. It's bent. I still have +2* of camber on my front passenger wheel.
I have seen the traction bars they sell. They are wicked
Old 08-17-2011 | 06:52 AM
piggylover1985's Avatar
It's okay, just drive without front passenger then :-)
Get a used one at the junk yard and save yourself some money.
Old 08-22-2011 | 09:13 PM
Tek310's Avatar
man bare front subframe is freaking 80+ dollars at a pick n pull.. 3 hours to remove and a day to remove mine and reinstall, EFF that. i will live with the positive camber for now.. it will even out when i drop the car.
Old 08-22-2011 | 10:11 PM
Yeah it's kind of pita job, would be easier if you have a lift :-)
Old 09-16-2011 | 02:17 PM
Tek310's Avatar
I'm gonna attempt to replace. I can't seem to get a good diagram on AllData. Anyone know how the rack n pinion is connected to it? Any tricks on getting the rear motor mount off abd back on?
Old 09-21-2011 | 07:36 PM
Tek310's Avatar
Thanks for the replies....
I used a 3lbs hammer to make adjustments to the frame. Fixed the camber issue on my own.
Old 09-21-2011 | 08:32 PM
I like the caveman approach. Thanks for the update.
Did you get into an accident, because that beam shouldn't bend on its own. Was it part #2 in the diagram above that was bent?
