Fuel economy trouble, 2.3 ULEV Accord.
Old 10-25-2012 | 10:17 PM
NFLightle, that's interesting; where are you getting that information?
I'm pretty sure the ULEV & non-ULEV engines use the same rotary valve for the IACV. Neither one has a FITV, that dissappeared in 1998 for all Accords.
Yes, the ULEV PCM is 32-bit, and the wiring harnesses are very different from the non-ULEV car.
I thought only the primary O2 sensor has any control over the fuel rate. (Yes, it's a wideband sensor and very different from the sensor on the non-ULEV car.) But I thought the secondary O2 sensor is only used to determine if the catalyst is still working OK; it doesn't feed back to fuel rate.
fperezal
12-15-2012 11:29 PM
jhillblessed
05-10-2010 10:55 AM
morphius909
12-04-2009 11:02 AM
iqoair
08-27-2006 11:39 PM
fperezal
11-03-2005 02:28 AM
