Fuel injection cleaner..
Old 09-19-2007 | 02:00 PM
d_10's Avatar
Default Fuel injection cleaner..
I would like to know if i put fuel injection cleaner through the brake booster is it ok,. or will it harm the engine..and will it cleaner the injectors.
Old 09-19-2007 | 02:18 PM
falkore24's Avatar
Default RE: Fuel injection cleaner..
I'm not sure that has been tested, but it won't go through the injectors as only fuel goes through them. Use Seafoam for the full engine internal cleaning ..... I've never used it, but I intend to try it. It's recommended by many highly regarded HAF members.
Old 09-19-2007 | 02:31 PM
I've used Chevron Techron in the gas tank. If you need to clean the injectors then your favorite cleaner has to go into the gas tank.
Sucking into the manifold will clean out the inside of the manifold, butthe cleanerwon't actually go thru the injectors.
What are you trying to accomplish?
Old 09-19-2007 | 04:45 PM
accord4sroy's Avatar
Try Seafoam or you can find BG44K. The BG44K stuff is expensive though. And, it can only be found at a dealer. I went to a Pontiac dealer and got the BG stuff before. But, usually I use Seafoam which works well.
Old 09-19-2007 | 08:09 PM
ckebottle's Avatar
I agree onf seafoam too! Seafoam is great stuff, just recently did it. Follow directions on bottle and you will be happy.
Old 09-19-2007 | 08:11 PM
RTexasF's Avatar
Super Member
Put it in the fuel tank.........oddly enough, as the directions tell you to do.
PAhonda
05-17-2024 04:53 PM
Draco
10-04-2006 10:22 AM
thunder_x
07-29-2006 10:11 PM
Jeff247
02-06-2006 10:00 PM
nrangerfan
05-19-2005 01:56 PM
