fuel injector cleaner
hey guys i was just wondering what would be the best injector cleaner for my 95 accord lx. im getting around 20 mpg and i would just assume i have some build up in there. air filter is clean so im working on the injectors now. thanks
FREE Injector clean;
Rev the engine to 5k rpm, pinch off the vacuum line at the FPR, let the engine go back to idle. after 5-10 seconds unpinch the vacum line.
This blasts gasoline thru the injectors at high pressure during a slow injector pulse.
You might trip an O2 sensor code
bg 44k ,, you can get jut a bottle to add to the gas tank or you can get the kit ( 3 pieces) where you hook it up to a vacc source and run the engine ( 1500-200 rpm ) till can is empty,, also included is the bg 44k to add to tank and a sprayer where you can clean the throttle plate as well..
been using it for years ,, does a great job
