Gas cap light
It is a relatively common issue with 8th generation Accords. The indicator will usually go away in a day or two of driving.
Honda has technical publications regarding turning the gas cap at least 3 "clicks" after every fill-up.
If the problem persist even with turning the gas cap at least 3 clicks, it may due to something other than the gas cap.
I just went through this two weeks ago on my 07 and was wondering why it didn't reset. When I held the positive and negative cables together it cleared it. I only changed the gasket on the cap. You can also clear the warning with a more than mediocre OBD2 reader. Good to know it will clear after a couple days on its own.
