Gas Smell
Old 12-23-2008 | 06:38 PM
steammer
Default Gas Smell
96 accord. When vehicle is sitting , idleing with the heat on,bring air in from outside i get a gas smell from the vents.When vehicle is movingthere is no problem with gas smell.
Old 12-24-2008 | 01:26 PM
Default RE: Gas Smell
ORIGINAL: steammer
How about maybe a leak in the floorboards and the fumes are floating up?
Old 12-24-2008 | 02:22 PM
finch13's Avatar
Sounds like you have a small gas or exhaust leak. Does it smell like fresh gas or burnt gas?
Probable places for a fuel leak:
-Fuel injector seals
-Banjo bolt for the fuel line on the fuel rail
-Pressure fitting on the fuel rail
-Fittings at the fuel filter
Probable places for an exhaust leak:
-Exhaust manifold gasket
-Downpipe gasket
-Catalytic converter gasket (either end)
Forgot something...
Pop the hood of the car and turn the key to ON/II to pressurize the fuel system. Go back under the hood and smell for gas. That would be an easy way to tell if its exhaust or fuel.
Old 12-28-2008 | 08:49 PM
Check for leaking fuel line running under the left side floorpan.
bjr001
11-25-2010 12:05 AM
jose310
01-13-2009 02:50 PM
steammer
12-24-2008 01:26 PM
pitree
08-09-2008 02:36 PM
periapt
03-19-2007 07:38 PM
Quick Reply: Gas Smell
