Gear grind in 5th when cold
I have a 2000 EX with 5 speed manual. In the mornings, I experience gear grind, going into 5th, until it warms up. Once the car has warmed up, no problem. Honda says it's the clutch, but I believe it's a syncro. IMO, if it was the clutch, it would continue to grind even after it warms up and I would expect to have some grinding in other gears also. Am I right?
