Gear grind in 5th when cold
Old 03-06-2013 | 08:53 AM
Roader's Avatar
Originally Posted by JimBlake
Also labeled as Pennzoil Synchromesh at auto-parts stores. Is that the same stuff?
Lots of opinions over at Bob is the Oil Guy forum. Some swear by ACDelco, some say Pennzoil works just as well. Only two quarts drain & refill...pretty cheap to try either or both, compared to the cost of replacing the synchro.
Random Cheese brought up a good point: if the trans oil has never been changed @175K then just changing the oil might fix the problem.
Old 03-06-2013 | 12:32 PM
Jet sitter's Avatar
Actually, I changed it at 60K, 120K and now I'm due again. That may well be the problem. No problems with the clutch.
accord99
02-21-2012 12:49 PM
cdarnt
02-23-2011 09:15 PM
fly68
04-06-2009 07:52 PM
low_go_91
04-12-2008 09:08 AM
