Good Idea??
Old 01-08-2007 | 11:39 PM
RTexasF's Avatar
Super Member
Default RE: Good Idea??
I'll go tomorrow and seek out some Permatex silver. To make sure I understand.........only a small dab on the plug is required. You don't coat the threads entirely, correct????????
Old 01-09-2007 | 04:45 AM
I try to puton a dab that's just about equivalent to maybe 1mm or 2mm diameter sphere. The stuff is kinda stringyso it's difficult to put less than that. Install plug, back it out, thread it in again, just to smear the stuff around. If you really want to check your 'technique', just pull the plug back out. You don't want any anti-sieze oozing into the combustion chamber.
Back to the original question/idea... When you do this, inspect the condition of the plugs carefully. They'll tell you a lot about the health of your engine. This may be even more important than preventing siezing.
Old 01-09-2007 | 09:05 AM
RTexasF's Avatar
Super Member
Will do. I always read the plugs for any abmormalities. With only 26K on the clock they should all be normal color.
Old 01-09-2007 | 09:23 AM
ORIGINAL: deserthonda
I totaly agree as well.....
And so do I agree, also permatex is the #1 seller in the USA for spark plugs..
Old 01-09-2007 | 01:34 PM
HondaRacer4Vtec's Avatar
I dont want to be a begger, but can you do a DYI for this with some pics, i would really appeciate this.
mck52689
07-14-2007 04:02 PM
Tyltong123
01-08-2007 06:00 AM
thunder_x
11-01-2006 08:05 PM
thunder_x
09-28-2006 12:00 AM
joshuaaaronalpert
12-30-2005 04:40 PM
