guages on cluster won't work
Old 06-02-2011 | 09:31 AM
widowmaker's Avatar
Default guages on cluster won't work
i have a 2000 accord lx and i just replaced the cluster lights to led. now the lights are changed and work but the speedometer or the tach and temp and fuel guage in the cluster dont work nor the digital odometer or pwr windows. i checked the fuses didnt see nothing blown and checked the plugs to make sure there pluged in and checked and replaced them nothing. i took a tester to them the fuses that fun the power windows under the the hood work but the fuses on the passenger side that run the windows dont get power same with the cluster but the lights are working on then. im sooo confused on not sure if its a ground or what any help plzzz?
Old 06-02-2011 | 09:46 AM
Take out Led's put back in originals and see if it works..if not..you screwed up something..
Old 06-02-2011 | 10:00 AM
widowmaker's Avatar
did nothing
Old 06-02-2011 | 02:42 PM
deserthonda's Avatar
chk fuse # 13 .. 7.5 amps ,, passenger under dash fuse box ,,, let us know if that's the fix
Old 06-02-2011 | 04:21 PM
widowmaker's Avatar
Default its still good
i changed the fuse nothe tested the fuse holes both sides no power
natwood68
02-24-2014 12:16 PM
njmodi
05-29-2008 01:11 PM
Calidude87
05-22-2008 03:27 PM
PJ_STYLES_95AccordEx
08-21-2006 11:45 PM
GLrunner13
07-22-2006 04:28 PM
Quick Reply: guages on cluster won't work
