Handbrake Adjustment
Old 11-17-2012, 03:07 PM
Silver6gen's Avatar
Didn't notice any thing wrong with the caliper today.
Things I inspected:
- Pins, they were lubed and the boots were still in good condition
- pads, the inner pad was a little unevenly worn so I swapped them (put the inner on the out and vise versa)
- Checked the spring - was ok
- Checked the cable - was also OK
- applied the brake on different levels and used a torque wrench to test the amount needed to move the tires. Both sides were within 2 ft lbs.
- noticed nothing wrong with the rotor or bearing....
- I also screwed in the piston a half turn to see if it just needed to be reset
So I am kind of at a loss, I will see if the pad swap made the difference. At least I know the caliper isn't frozen.
Old 11-18-2012, 07:17 AM
Humm....these drive you carzy. Let us know how it comes out.
Old 11-18-2012, 07:55 PM
How'd you swap inner & outer? Isn't there metal tabs on the inner to make a squeeking sound when they wear out?
abhijitgp
08-15-2011 04:20 PM
jasonfridlund
06-14-2009 11:32 PM
uk.accord
10-04-2008 12:15 PM
uk.accord
09-22-2008 01:52 PM
jo3lam
06-27-2007 10:54 PM
Quick Reply: Handbrake Adjustment
