hard start when cold and damp
Old 11-30-2009 | 08:46 AM
Originally Posted by ejkrech
... same symptoms on cold starts but i believe i'm getting spark...
Why "believe" you have spark? TEST it then you'll KNOW.
Old 12-01-2009 | 09:00 AM
ejkrech
Yep, tested and there is spark, and fuel too. I just pulled a plug and sat it on top of the valve cover and cranked it over. The spark ignited the fuel vapor being pushed out the plug hole. I've had the car taken to my cousin who is good mechanic, i suspect the head gasket is bad. It may be an unrelated problem i discovered but i noticed pressure would build in radiator when i crank the engine
Old 12-01-2009 | 09:42 AM
Pressure buildup in radiator during cranking sounds like a headgasket. Maybe antifreeze on the spark plugs contributes to hard starting?
Try a compression test?
reddem0n
02-23-2015 08:50 PM
dschnarr
10-04-2011 11:23 PM
joshualittlefield
05-19-2011 09:22 AM
natedbrbr
06-11-2010 12:21 PM
wheels
12-14-2008 07:15 PM
