Have oil in where the spark plugs go!! 01 accord 4cyl
I have a puddle of oil where the spark plugs go in my car...
Also can I eliminate the heater in my car I dont use it because I live in Florida and my A/c doesnt come out cold(already did freeon and have a pretty new a/c system
What engine? Vtec or non-vtec? Did you do any recent service on the car? It may be the sparkplug seals in the valve cover or the rocker arm seal. Please gurus correct me if im wrong.
I cured mine with replacing the sparkplug seals in the valve cover but mine is a 96 accord lx, im not 100% sure if the same goes for your accord.
Goodluck
Goodluck
there are several things that could cause this. I'd start with the plug seals.
How much oil are we talking about?
Elemintating your heater would be a pain in the butt and wouldn't do anything for you. If your heater control (can't remember the actual part name) thingy is working then the heater core wont even be hot. The problem resided with your AC.
Check out this thread it might help you deal with with the problem
https://www.hondaaccordforum.com/for...ires-fix-3088/
The 2001 engine doesn't have the lower seals that are mentioned in that post. You only have the upper seals, which are normally part of the valve-cover gasket set. Easy to replace, but pay attention to their shape so you don't put them in upside-down.
For the heater, you can verify that the control valve is closing off. There is a cable adjustment that can be done....or pop the cable off and manually close it. Still need to be sure the valve is working - usually they fail internally - meaning it will "look closed" but still allow coolant to flow thru.
