Headlight bulb replacement '04 Accord EX
Old 02-13-2011 | 01:32 PM
ston57's Avatar
Default Headlight bulb replacement '04 Accord EX
I know it's here somewhere but can't seem to find it.
Need to know method to replace passenger side low-beam bulb. I can't find my manual either, so instead of that expense I thought I ask here. DO I have to access it from underneath or can it be done from up top? Looks difficult either way. Thanks in advance.
Old 02-13-2011 | 02:02 PM
For low beam, remove the inner fender cover is what shop manual says. You'll have to remove wheel for access.
Use search of "headlight" to see if you can find any leads, pics, on this site.
Try youtube "honda accord headlight bulb replacement". Lots of videos.
Old 02-14-2011 | 11:36 AM
Here's the info. from the owner's manual.
Attached Thumbnails Headlight bulb replacement '04 Accord EX-low-beam-bulb-replacement.jpg   Headlight bulb replacement '04 Accord EX-instructions-continued.jpg
Old 02-14-2011 | 12:38 PM
Thanks for that Redbull. This is lot better than removing entire inner fender cover. The shop manual did not make that clear.
Old 02-15-2011 | 09:04 AM
ston57's Avatar
Thank you for the info. Found that I had to loosen screws on light retaining ring before I could turn (twist) it to come out. Appreciate the quick replies.
Old 02-15-2011 | 08:51 PM
g22cd5's Avatar
Supper Moderator
why are we still posting and answering questions in the area of the forum????
OP - need to read the rules and post in the right area...I won’t delete since you have some responses...next time it will be gone...post in the right area.
Old 02-16-2011 | 09:05 AM
ston57's Avatar
Many apologies! I thought the do-it-yourself section was for questions regarding doing things yourself. I'll re-read the rules. Sorry.
Old 02-16-2011 | 11:23 AM
The description that shows up in the general list of boards isn't the best it's actually kinda misleading. And us mods & admin can't change that.
But we're trying to make the DIY forum into a place for good detailed write-ups.
https://www.hondaaccordforum.com/for...ad.php?t=26638
kouken
01-24-2012 02:41 PM
kdgdag
11-10-2011 08:31 PM
superballz00
01-19-2008 07:30 PM
indy49
01-30-2007 02:18 PM
sskkf
01-19-2007 05:23 PM
