headlight housing assembly problem
Old 05-14-2006 | 08:10 PM
96accord's Avatar
Default headlight housing assembly problem
Hello anybody/everybody...got a problem with my right front headlight. The headlight itself is fading to a yellow like appearance and I need to replace it. The corner light has a crack in it allowing water to get into the housing area causing the faded appearance. Another problem is that the weather stripping around the light is essentially gone. I was wondering if I should get a whole new headlight/cornerlight assembly or should I just replace the cornerlight and just clean the headlight since the main problem seems to be coming from the cornerlight. Also, I have looked at a manual and it doesn't say how to take out the whole headlight assembly...how do I do this and how hard is it. If anybody has any suggestions or tips, it would be greatly appreciated. Thanks
Old 05-15-2006 | 07:03 PM
deserthonda's Avatar
Default RE: headlight housing assembly problem
you can try replacing just the ftrt side parking marker lense,, if problem continues ,,then i would replace the headlite assembly,,
to replace it, you need to remove the bumper
Let me know if you want to replace the headlite i will give you instructions....
Old 05-16-2006 | 12:35 AM
96accord's Avatar
thanks for the help desert...I will replace the corner light first and if that doesn't work, i'll go with the whole assembly. If that's the case, i'll contact you concerning the instructions. I have the Chilton manual for my vehicle which has helped in the past but not with this situation. I may try the Haynes manual. Thanks again.
sonnyleq
05-26-2008 05:53 PM
tomatocity
02-18-2008 01:07 PM
tomatocity
01-31-2008 10:42 PM
steviebix
04-21-2007 12:37 AM
sskkf
01-19-2007 05:23 PM
