Heat not working properly
RE: Heat not working properly
OEM T'stat is 195F, not 160 or 180F. However, I doubt this is reason for lack of warm air. A cooler thermostat will result in poorer fuel mileage, increased engine wear, oil contamination, and other bad things. Get an OEM thermostat installed.
Check the heater core valve and make sure it is opening fully when Temp setting is at max. Push/Pull wire may be broken or **** may be damaged. You can open the heater core valve by hand from under the hood.
ORIGINAL: TexasHonda
Along with that information, also make sure your anti freeze is at about 60-40..60% anti freeze and 40% water..the water has got to boil for the heat to come thru...if it doesnt boil ..not much heat..also check both of your hoses..upper and lower..they should be hot..
Angelo, I gotta disagree. The coolant does not have to boil for heat to work. You dont really want boiling in the cooling system. Boiling usually means the radiator cap is not holding the correctpressure.
Have you checked the heater valve to make sure the cable is opening & closing the valve properly? Ignition needs to be ON but engine doesnt have to be running.
Heater valve is back towards the firewall on one of the heater hoses. Have someone turn the dial all the way back & forth while you watch for the cable to push/pull on the little lever at the valve.
Cleaning out the cooling system is a goodidea. Some chemical cleaner to dissolve scale. Im not sure the best way to prove it needs that, other than try it & see.
The impeller vanes of the waterpump might be eroded/corroded so it doesnt pump so good. But somehow I dont think thats a very common thing. If you let your coolant get corrosive, theres lots of other components (radiator) that would start leaking first.
kyle94481
08-03-2011 07:02 PM
