heater blower relay
Old 04-01-2008 | 05:42 PM
kool77
Default heater blower relay
I have a 2003 Accord LX. The blower motor suddenly stopped working. I checked the fuses, and they were good. I got no voltage reading on the harness to the blower under th glove box. Any suggestions? Thanks
Old 04-01-2008 | 07:41 PM
Default RE: heater blower relay
Did you check the fuses in the engine fuse box?
The blower motor relay or the heater fan switch are the next electrical component to check. The relay is in the dash fuse box for a 95, but I am not sure where it is at for an 03 accord. If there is a relay that is the identical, then swap them and see if the blower works. If it does, then the problem is solved - get a new relay. You can jump the proper terminals, but I do not know which ones to jump.
Honda Man For Life
04-09-2012 10:38 AM
CougarMark67XR7
04-05-2009 05:15 PM
MSA
11-14-2008 02:26 PM
SM90Exi
11-13-2008 10:42 PM
billgrego
09-28-2007 12:37 AM
