Help 97 accord
Old 03-15-2021, 09:37 AM
John97's Avatar
Default Help 97 accord
Ok got this car it had to have inner oil seals replaced inside the distributor set 2 years new injectors and starter and plugs it cranks but wont start gets fuel fine and spark ive had to replace timing belt but lost this keyway anyone know where to buy it?
I need the keyway for this anyone know the part number?
Old 03-15-2021, 02:09 PM
Seanjordan20's Avatar
You can get it from the dealership, junkyard or online source. Here is one on ebay
Old 03-16-2021, 10:20 AM
Was the above what you were looking for? You haven't responded?
Old 03-29-2021, 07:03 PM
John97's Avatar
sorry been busy moving and packing bought it and it would not fit its spots to be narrowed at one end and that was to big would not fit
Old 03-29-2021, 07:25 PM
That's definitely the part number for that model. Was it an actual Honda part that was sent to you.
Old 07-14-2021, 06:30 PM
John97's Avatar
I had finally got it to fit got timing belt on have not been doing much with it lately I'm fixing to replace all my vacuum hose lines should be ready to start soon
Old 07-15-2021, 04:05 PM
John97's Avatar
Replaced fuses doing prosess of elematntion
Old 08-10-2021, 05:39 PM
John97's Avatar
Default Vacuum hose size
What's the vacuum hose size for my car ? Does anyone know?
Old 08-12-2021, 07:44 AM
The parts list shows it as 3.5mm.
Old 10-15-2021, 12:03 AM
John97's Avatar
Ok replaced vacuum hoses used starter fluid getting spark fuel back fired a couple of times still won't run spark test shows good strong spark
Quick Reply: Help 97 accord
