help- accord 2000 4cyl. tranny drain
Probably time to get professional help.
Or if you have a welder, weld a large nut to the bolt. IMO, a large ez-out will only round the hole further due to shallow depth of hole.
Maybe enough edge on the flange of the bolt to grip w/ vise grip?
when I do something like that I spray it with pb blaster and let it soak for an hour. After I bang the next size in and get it off. Hasn't failed me yet. If you try it make sure you have a replacement. If it's like all other accords I can't see how the whole bolt is stripped to the end
teto
04-07-2009 10:11 AM
jon02accord
03-26-2008 10:54 AM
