Help anyone with a 99 honda accord 4 cyl. v tec
Hi, this is my first post and I need someone's help. I was replacing my starter yesterday cause it went bad and I found a little hose that I couldn't find where it goes. So could someone do me the favor of checking their car to see where it goes. I have a 1999 accord, 4 cylinders, v tec, automatic transmission and the hose is connected to a little tube under the motor mount next to the battery. I can't see the tube where the hose is connected but I can feel it. The hose is exactly under the motor mount so if someone can check their car I will greatly appreciate it. Thanks
I will try to get pictures tomorrow. I don't think it's a vacuum hose but not sure. The hose is in the passenger side under the motor mount that is behind the battery. I know one end is connected to a nipple or tube that is under the motor mount but the other end is loose. Can anybody help??
Well, that picture is the trans case showing a bent-over hose nipple on top. I'm not real sure about the mount, but I suspect it attaches with the studs #11 & 12. You said the hose is attached one end to a hose nipple on the trans case?
Hey Danny,
I have the same car and on the right side ( passenger side ) there is a little hose that is being squished by the motor mount. Mines is not connected either. I though that it went somewhere and that maybe a mechanic had accidently left it unattached. Either way I hope my answer helps.
Hey Danny,
Hi Redbull,
Well mainly because I just aquireded the PDF repair manual for my car which is the 99 EX and I thought I would help. When I originally came across this website it was by searching via Google for very specific problems and I found the answers were on threads that were very old. I just wanted to contribute since I thought it might help someone since I had this manual.
