Help with break light
Old 01-09-2011 | 05:57 AM
IslandAccord's Avatar
Default Help with break light
So I just cleared my "breaklamp" light by changing some blown break light bulbs. Now the "break" light stays on. Even though my e-break is down. Anyone got an idea of what the problem might be. Suggestions greatly appreciated.
Old 01-09-2011 | 07:54 AM
Check the fluid level and the sensor in the master cyl. Aslo be sure the e-brake is releasing all the way.
For anything further we'll have to know what year, model, ect you are working with.
Old 01-09-2011 | 09:46 PM
Check for dirt or corrosion in ALL the bulb sockets back there.
That "brake-lamp" warning light works by comparing wattage among the different bulbs. Occasionally someone has to replace ALL the bulbs just so they match each other.
Old 01-12-2011 | 04:57 PM
I filled the break fluid to max. So the sensor should be fine. And the break lamp light is off now from changing the bulbs. Thanks but I'm working with a 95 accord sedan sohc non-v. I checked the e break and it looks like it's realeasing all the way down onto the sensor. Might I have a bad sensor? It has been raining a lot in hawaii. But if you got anymore opinions I'm up for it. Btw thanks a lot guys
Old 01-12-2011 | 05:43 PM
OK I re-read your first post & I was confused...
The brake-fluid reservoir has a float-switch in the cap. Also there's a fine mesh screen thing inside the reservoir. Sometimes the mesh screen gets warped & drags on the float. Check for that. Or unplug the wires from the brakefluid cap & see what it does. (Don't leave them unplugged; once you fix this you'll want that warning back working again.)
IslandAccord
01-09-2011 05:35 AM
louh
02-13-2008 01:06 AM
jbl2bgone
11-07-2007 10:56 AM
bigheadballer
08-27-2005 09:16 PM
bigheadballer
08-27-2005 09:16 PM
