Help! Check Engine Light & O2 Sensor
Hello -
I have a 2001 Honda Accord LX 4cyl VTEC ULEV(103k miles)- I got the light on and went to Autozone to read the code, it indicated primary o2 sensor was bad... I replaced with genuine Honda part and expected that the check engine light would go off automatically. Do I have to reset this or will it go off by itself after a few rides as it would if the gas cap were loose?
Thanks! James
Thanks! James
RE: Help! Check Engine Light & O2 Sensor
You can reset the ecu and clear codes by disconnecting your battery for approx. 15 min or more to drain the capacitors inside of it. This can also be accomplished by removing the 7.5A backup fuse. I haven't tried the 2nd method, but you won't lose radio station presets. Let us know if you still have a CEL after.
78gaw
01-20-2010 09:45 AM
ddold@gkschools.org
02-14-2008 03:20 PM
6genex
10-03-2007 07:32 AM
