HELP: Damaged control arm and CV Shaft popped out
So im going through all this crap just to change these stupid captive rotors. End of day two. i removed the right spindle to bring it to the mechanic to have the hub and bearing removed and a new one pressed in since 9/10 times the bearing gets messed up when you do the captive rotors. The lower ball joint nut is rusted and wont come out. So I cut the lower ball joint and theres the cut bolt stuck in the lower control arm and the arm is slightly cut into. Im thinking itd be easier and safer to replace the entire thing. Any suggestions?
Also, the cv shaft popped out. How do I get it back in?
I swear, next time I need to do any work on the front suspension Im buying a new car.
I just did some work on my daughter's '94 Accord. I tried everything possible on the lower balljoint. I torched it, used pblaster, and a 15 lb sledgehammer, swore at it. It wouldn't come out of the control arm. I ended up buying a new one from rockauto. The cv shaft should pop back in if there is no damage. I lined it up straight and had my son tap it back in. Use a block of wood over the outside spline so it doesn't get damaged.
was a different vehicle, but same part and function.
mogilir
04-01-2009 07:57 PM
