help finding TCM in a 97 Accord Lx
i just bought a 97 accord lx auto with 185k and the d4 light blinks when i am driving. i have been looking on this site and some say it maybe the tcm (transmission control module) that needs to be replaced. I looked on http://www.dhost.info/accordinfo/hon.../transauto.pdf at sectiion 14-85 and i looked at my car and took the carpet up on the pass side and unbolted the 4 10mm bolts that hold the metal ecm cover on and all i have is the ECM on the right side of the cover and i dont see my TCM. Where else would it be located ? Please help. I have a buddy that has a TCM out of a 97 accord that hes gonne let me test out.
tcu
not sure this is right, but on my 92 i remove the right kick panel , take up the carpet, there should be two units bolteed to the bottom side where you removed the four bolts, rthe samller one should be the one, i beleive yours is the same. be sure that the test unit is the same numbers, lx and dx should be the same , ex and se the same but not the same as lx end dx. good luck, did you check for code faults??? need to do so
Frank Allen
Frank Allen
i took the ecu cover out and all i see if the ECU, i dont see the TCU that i thought should be bolted next to it. i wonder if my car was a manual car and some one swapped it out. If not then i am not sure where the hell its at. Its gotta be some where b/c it prob wouldnt shift with out the TCU attached some where
