HELP!! need to find out the name of this part!
This part started squirt hot radiant fluid all over my engine this morining. I went to the dealership and they printed out a blueprint but that part did not have a name nor a part number. Please Help!! Im attaching two photo so hopefully you can diagnosis the part.
Last edited by sergio429; 09-19-2009 at 08:11 AM. Reason: 2000 Honda Accord Coupe. 2.3l 4 cyl
I'm guessing it's a 96 EX
That part is called a breather pipe, it has a coolant transfer tube joined to it.
I'm pretty sure the part is called out in the "Breather Tube" parts page., or it is in hondanet parts listings.
try this link;
http://www.hondaautomotiveparts.com/home.htm
try this link;
Two metal tubes stuck to each other side-by-side. One carries air for the crankcase vent system. The other tube carries coolant, just to keep the air-tube warm.
Is the steel tube cracked? Or did the rubber hose broke open? Busted hose clamp allowed the hose to be disconnected?
nicolaselias
03-24-2008 01:12 PM
