Help newbe 97 accord
Okay guys just got the rocker arm assembly reinstalled all i had to do was turn the engine to tdc to have more clearance I guess I was a little afraid that I was going to mess something up. Changed all the gasket and seals for the under the valve cover. Engine starts right but I am currently not getting coolant through the entire system so I think it could be radiator, fans which are not working or the water pump. any ideas? Thermostats been changed out, radiator hoses, fan relays and fan sensor. Thanks again.
I agree with Jim's ? but I'd also like to ask if you bleed the coolant as/when you were refilling it. What is the temp gauge doing?
Thanks for the reply JimBlake and PoorMan212. The bleeder was released but no coolant is reaching that far. Like Jimblake said obstructed tubes in the radiator I believe. When pouring antifreeze into radiator it over flowed and stopped circulating. None of the overflow was going into the overflow reservoir so I went ahead and ordered a new radiator. Did not realize that the car had so many problems when I bought it. Now I have to get the heater and ac to work. Lol pulling hair.
Disconnect the heater hoses (2 hoses going into the firewall). Use a garden hose to flush through the heater; first make sure the heater valve (cable-operated) is OPEN.
If you need to do some chemical flushing of the heater core, you may as well try to do that without the brand-new radiator in place. You might even get a lot of crud out from the heater core by flushing backwards & forwards & backwards again.
Hello Jimblake. I just put the new radiator in yesterday and did not get your reply on time. Anyways I did went ahead and do a radiator flush when I notice that the bleeder was not bleeding anything at all. Do you think I should just change out the heater core? I have my dash board out already so should I just do that. Well I'm gonna try the flush first and see what comes out of it. Then I'm going to check all the wires and plugs to see if everything is functioning properly. Car is now working just fine after installing new radiator. Hopefully I can get the bleeder to work and find a way to use a water hose. live in apartment in la kinda hard. Thanks again JimBlake!!
