Help passanger side window and lock dont work.
So the problem is that after removing the door panel and installing a new speaker and putting everything back together the passanger side mechanical lock and window dont work, even if you press them from the driver side. There is no sound at all. PLEASE help!!
I had the battery disconnected for awhile could that have anything to do with it?
RE: Help passanger side window and lock dont work.
first off , input yer and model in your signature
secondly , did you plug everything back on ?? I would chk to make sure , is the switch for the window on the driver;s panel turned off >>??
and NO having the battery disconnected should not have caused the problem,
my guess would be that either you unplugged something and forgot to plug it back in, or while you were installing the speaker you accidentally cut a wire or pinched it in the door panel and snapped the wire. (the rubber might be intact around the wire, but the wire inside can still seperate if its thin enough. similar to what happens to headphones after awile.
RoXeTTeMaN
08-05-2006 03:22 PM
