HELP!!! Problem with the Emissions and engine control system.
Old 02-26-2006 | 05:14 AM
codyheit
Default HELP!!! Problem with the Emissions and engine control system.
Hi
I don’t know a lot about cars but am interested in learning about them.
Today when driving my car the following problem occurred:
The drive four light begun to flash and then the Speedo and the trip computer stopped working but then sometimes again started working. As I was on the highway I couldn’t pull over but as a kept on driving the engines emission and engine control light came on. The car drives like normal most of the time but then sometimes it feels like the car is going back and forward as if it is having problems using the fuel.
It’s a Honda Accord 1994 VTI auto.
Does anybody know what might be causing this and how much it would cost to fix (AUS or US dollars)?
Old 02-27-2006 | 04:32 AM
lightshow's Avatar
Default RE: HELP!!! Problem with the Emissions and engine control system.
unfortunately you havent given us much to work with but it does sound like a VSS vehicle speed sensor is going out. prolly about 400 to get it fixed but im not sure. it will need to be diagnosed properly
Old 02-27-2006 | 06:11 PM
deserthonda's Avatar
As lightshow suggeseted it sounds like a VSS. ,, pull the codes and post them here,, if engine code is 17 it is the VSS, part is around $ 150. labor no more than 80 dollars
browniebear
04-13-2013 12:42 AM
19Accord97
05-09-2006 08:13 PM
djsinister
03-01-2006 04:11 AM
evgentry
05-11-2005 01:40 PM
evgentry
11-19-2004 11:55 PM
