help!!!!!!!speedometer not working
#21
If you have a CEL, what is the code expressed? Check at autozone for a free read.
If the code is for VSS, then your installation may have been faulty. Did you install the tiny mechanical link between the drive and the VSS? W/o this link the VSS does not turn and generate a signal.
Hmm
Dear TexasHonda,
I'm not sure what you mean by that but I can say that there was a gear that went directly into the transmission. ANyway, you might be on to something because the VSS from Autozone looked different from the one I removed from my car. One option will be for me to purchase one from the dealer instead. I have my own code reader and the code read out as VSS, but that can be a lot of things besides the VSS.
Thanks for your input.
E
E
#25
Cluster not working
Entire cluster isn't working on mine all the lights come on but none of the needles are moving
#26
An easy thing to check is loose or flaky connections where the wiring harness plugs into the cluster.
Beyond that, we need the year, model, engine, etc. There's already a couple different cars in this thread, so maybe it'll be better if you start a new thread.
