Hitachi Distributor Internal Seal
Im not sure if anyone has found this before or not, but after doing a lot of ebaying, i found a seller that has the internal seal and the outer oring for about $10
.ebay.com/itm/honda-distributor-shaft-seal-for-F22B1-F23A1-F23A4-and-F23A7-with-o-ring-/180970632380?pt=Motors_Car_Truck_Parts_Accessories &hash=item2a22b0b4bc]Honda[/url] Distributor Shaft Seal for F22B1 F23A1 F23A4 and F23A7 with O Ring | eBay
From what i saw in the pics it looks as though you changed the outer oring. the only way to get to the inner oring is to get that pin out on the outer side. I took my dist off recently and replaced the outer oring but was unable to get that pesky pin to come out so i was unable to replace the inner ring even though i have one laying around
Firefighter, look at his pics again:
There's more. The pics and verbiage should be in the DIY section.
I drove the pin out with a 1/8" pin punch cradling the gear in a notch cut in a 2X4 held in a vise. It is tight! 5/32" punch with a heavy hammer would work better than what I used.
Do not pull or turn the shaft bushing like I did! (Added by grannie613 on 10-30-2012 07:23 PM)
grannie613
DIY Answers.
19
11-21-2018 10:26 AM
Stiffy
03-09-2009 01:44 PM
ZMan3000
05-15-2008 04:10 PM
