honda accord 2000 v6 auto trans stalling / no idle
Old 10-13-2010 | 07:06 PM
alex-accord's Avatar
Default honda accord 2000 v6 auto trans stalling / no idle
Hello Everybody,
First of all, nice forum you guys got here!
Now to the reason of this post; My 2000 Accord v6 Automatic stalls sometimes. It happens when I go to the grocery store, park the car and try to start it again within 10-20 minutes. The engine will start, and then stall. The rpm needle will not go hgher then 400-500 rpm. It seems like it is running on 5 cylinders. Also the check engine light comes on.
When you hold the gas and keep revving for a couple of minutes the problem goes away and it idles normally again. When you will try to drive away when it does this, it will stall. So holding the accelerator for a couple of minutes is the only way to let it run normal again.
It will only happen with a hot engine.
Sometimes the problem does not occur for a couple of months and then it comes back and happens everyday for a couple or days or so.
When it does this, the car does not smoke or smells of gasoline.
I went to the garage (not Honda dealer) and he red the fault codes with the computer. The mechanic said that the fault codes told him there was a misfire on all cilinders and he did not know what to do about it. He was not very clear in what he did check.
I am gonna bring the car to a garage again soon, but I want to know if there is something I can do first myself. Or does anybody had a similar problem and knows where to look. Or does somebody know in which direction to look? I am afraid the garage won't find the problem again and will just give me another bill.....
Looking forward to hear from you guys!!
Old 10-13-2010 | 07:56 PM
Go to someplace like AutoZone & have them plug in a scanner & read the error codes that are stored from the check-engine light. (normally free)
Get the actual code number (P1234 or whatever), not just the guy's explanation.
Sartan36
11-06-2012 11:35 AM
argarcia86
07-03-2012 11:36 AM
bec
06-25-2011 03:26 PM
toneslish
06-28-2010 06:53 PM
vipernj
10-07-2008 12:04 PM
