Honda Accord Battery upgrage
Hi, I am trying to replace/upgrade my 51r battery of honda accord 2012 SE with group 24f or 35 battery and noticed that battery clamp has a trapezoid like structure (circled with red paint) to clamp the small 51r battery, is that detachable or do i need to buy new v6 clamp to upgrade to larger size group 24f or 35 battery?\
Also, since there is considerable gap left between the 51r battery and battery cover, do i need to buy new battery cover + battery tray for larger battery?
thank you.
thank you.
Yes, that plastic bar that holds the battery in place. The thing that you circled does come out. I recently took mine out. You can take that off. And also after you take that off. Then you will take the battery out. Then you will see if there is a another plastic bottom that is bolted in probably. What you probably want to do. Is measure that to see if your new battery can be put in there.
Heck you could probably take a set tools and take your car down to wherever you are going to buy the new battery. And just quickly take it out. And see if you can try to install the new battery in it. If it's like parts store, sometimes they could even help you install it for you.
Just be careful you don't drop any small nuts. If it goes under the car sometimes you wont be able to find it. Then you will have to take the other nut off and go down to the hardware store and match it.
oh i think you are talking about the j shaped bolt, i know that can be taken out but i was talking about the thing pointed with purple arrow, can that be detached from handle as it will not allow be to add larger battery than 51r.
Edit: I'm trying to research this for you to see if I can find any information out. I found a video (although not for your year of the honda accord). That there are suppose to be replacement parts you have to buy when you upgrade the battery (although another video claims you do not have to replace most of them). In this video it does mention a wider plate (hold down bar) to go along side the top. You might indeed need to upgrade that plate (hold down bar). I'm not sure what the prices are on these parts. If it's too expensive, if it were me. I would try to mod it.
And to answer another part of your question
2013 - 2017 Honda Accord (9th Generation) ...
2008 - 2012 Honda Accord (8th Generation) .
compiler
04-04-2014 09:00 AM
RoKnAzn
01-19-2007 01:56 PM
