Honda accord check engine cord
Hello everyone:
MY engine stall really bad and following codes occured:
- P0301
- C0700
- P0603
- C0103
- P0103
P0301 is a misfire on the #1 cylinder.
P0103 is high voltage on the mass air flow sensor.
C0700, P0603, and C0103 are not listed in my shop manual.
Before replacing any parts, you should do some diagnostics. What are you using to read the codes on your car. Does the scanner give you any description of the codes I can't find?
Have you done any recent work on this car before you started having the stalling problem?
@PAhonda I have not done tune up on this car, got this car in 2016 with 88000 miles and have not done any tune ups yet with this car now mileage is 134000. The car has been burning excessive oil and has head gasket leakage as well.
As far as the description of the code, my scanner dont have any description for the code and I did not had any recent work on the car. Just on last friday I was on a traffic light where engine light and VSA light came ON.
aa8ball
09-08-2014 07:49 PM
