Hot air issues
Hot air issues
I have a 2007 Accord ex-L V6. So I’m having issues diagnosing a problem I’m having with my car not switching to hot air. I replaced the heater control valve thinking it was the problem no luck. I then consulted a family friend about the issue he suggested checking out the blend door actuator(s). Checked them they weren’t moving so I ordered a new driver side actuator to try out to see if that was the problem and nope. The car already had an aftermarket radio/radio install kit in it when I bought it. The installation kit replaced the factory climate control panel and now I’m stumped on what to check next any help would be greatly appreciated.
I was thinking that maybe the factory HVAC controls were moved to your aftermarket setup. If you go to the common diy thread in the gen tech help forum, there is a link to get hvac codes for the 03-07 accords. It is worth a shot to get hvac codes.
