How to clean EGR ports for a 94 accord EX VTEC
Old 09-16-2009 | 03:32 PM
fusionstar's Avatar
Default How to clean EGR ports for a 94 accord EX VTEC
I've been meaning to clean the EGR ports for the longest time now. But looking at the fuel relay and all the things I would have to remove, I dont think I can comfortably say I can do a clean job without screwing something up. Can someone tell me or show me how to do it. Will I need a new EGR gasket while im at it? Thanks
Torn
Old 09-16-2009 | 04:06 PM
deserthonda's Avatar
go to the DIY section ,,, How to clean egr ports
http://home.comcast.net/~em-engineering/T2T013.pdf
it would be a good idea if members would first try to find answers in the DIY section before asking for help..
Old 09-16-2009 | 05:10 PM
fusionstar's Avatar
I've already read it. I have the PDF in my computer. I need to know how to safely remove the fuel rail to access the EGR. What do I need to take off and what do I need to leave on.
Old 09-22-2009 | 11:30 AM
hondadude's Avatar
Old 09-23-2009 | 12:57 PM
fusionstar's Avatar
Dude.. you are a fricken life saver man.
If you were near here, i'd buy you a beer.
Old 01-13-2010 | 07:14 AM
wunderbra's Avatar
Default Gaskets needed?
I also have a CEL 12 and plan to clean the egr ports. Great job on that write up Hondadude! Question for me is if I will need new egr manifold gaskets and O rings for the injectors. There is no where to get them around where I live for a couple days and don't want to be stuck in the middle of the job if they tear or won't seal when I put it back together. Don't wan't to buy them either if I probably won't use them. It's a 94 EX with 170,000 miles. Also, is that chemtool spray okay for the O2 sensors? Thanks
Old 01-20-2010 | 07:10 PM
k9homan's Avatar
My buddy, a honda tech, just did my girlfriend's 1994 Accord EX... Another DIY if you want more pictures...
http://www.hondacarforum.com/honda-t...smog-test.html
Old 01-28-2010 | 10:52 PM
hondadude's Avatar
whoa ...wait a minute wunderbra...code 12 on a pre 96 Honda is a different story
Old 01-29-2010 | 06:34 AM
wunderbra's Avatar
What is different? The shop manual for the 94 says that an MIL with a DTC code 12 is for egr.
Old 01-29-2010 | 08:13 PM
hondadude's Avatar
well it means the lift sensor isn't reading what the ECU expects.
It could be the lift sensor in the EGR valve or vacum not going to the EGR valve.
But there is no "low flow" code for OBD 1 cars, so plugged EGR ports will not throw a code 12.
Quick Reply: How to clean EGR ports for a 94 accord EX VTEC
