how do you recycle used auto fluids
Old 09-18-2008 | 10:46 PM
faosh's Avatar
Default how do you recycle used auto fluids
Its easy to recycle used motor oil. Not quite so with transmission fluids, brake fluids, and power steering fluids. The auto parts store don't take them back. To those of you who are not mechanics, how do you recycle them?
Honda dealerships typically take them back provided we take the fluids back in the same container as it was sold. So I am forced to buy fluids from them, just so that I can recycle them back.
Old 09-19-2008 | 09:29 AM
falkore24's Avatar
Default RE: how do you recycle used auto fluids
all the fluids mentioned are oils ..... Strauss near me throws them in with the recycled oil. Especially tranny fluid ..... that's the same thing as motor oil with a few additives and red dye.
Old 09-19-2008 | 09:34 AM
I agree. I mix trans fluid and I save old brake fluid for use as a cleaner on brake parts (no solvents are recommended).
Old 09-19-2008 | 09:46 AM
falkore24's Avatar
^^^ I use brake cleaner!!! That stuff cleans anything!!!! ..... and it cools parts quick, fast and in a hurry!!!!
Old 09-20-2008 | 11:05 PM
faosh's Avatar
How about antifreeze? Its not oil and is poison. How do you recycle coolant?
Old 09-21-2008 | 06:59 AM
This is not federally regulated. Each state has their own set of impractical guidelines. No easy solution here that I know of.
Old 09-21-2008 | 06:36 PM
falkore24's Avatar
ORIGINAL: faosh
The Strauss Auto near my house has a separate container for it.
Old 09-21-2008 | 07:35 PM
I know my local Autozone takes oil and maybe coolant for free
Old 09-21-2008 | 11:50 PM
Check your local sewage-treatment department. Anti-freeze is sometimes OK to pour down the drain. It's a heavy alcohol, and itis bio-degradable. Its not particularly healthy for home septic systems; it can disrupt the little critters in your septic tank.
Old 09-22-2008 | 09:12 AM
falkore24's Avatar
Antifreeze is usually ethylene glycol; the green stuff anyway. It is poisonous, so I doubt that anyone wants it in their groundwater via leaky sewage pipes. Amsoil uses propylene glycol which is safe, but I doubt the sewage authorities recognize the different fluids.
MessAround
06-19-2011 08:34 PM
mklovell
01-23-2011 02:27 PM
t3baird
03-19-2008 10:38 PM
Mrheat
11-13-2007 06:45 PM
accordfan
04-21-2007 07:02 AM
