How do you tighten the steering wheel adjustment handle?
Old 12-22-2007 | 07:16 PM
razcob's Avatar
Default How do you tighten the steering wheel adjustment handle?
I have the steering wheel set to the highest upward position. When I grab the wheel to get out or pull down slightly on the steering wheel, the steering wheel slides down, even though the adjustment handle is in the parked upward position. Also, the handle to adjust the steering wheel will sometimes fall downfrom the parked upward position. Is there a way to tighten this lever and maintain the steering wheel in the locked position?
95 Accord EX , 2.2 4cyl, ABS, Auto
Old 12-23-2007 | 04:50 PM
hondadude's Avatar
Default RE: How do you tighten the steering wheel adjustment handle?
remove the lower steering column shroud and you should be able to see the tensioner
Old 12-23-2007 | 09:12 PM
razcob's Avatar
I seperated the two halves of plastic steering wheel shroud to expose the tensioner assembly. I still don't know how to tighten the tensioner? What do I look for? What tool?
Old 12-23-2007 | 09:42 PM
nafango2's Avatar
try looking in a service manual. There is a link in the diy section to a bunch of service manuals.
Old 12-29-2007 | 02:29 PM
HondatechAV6's Avatar
you don't need the spring scale, just slightly adjust it until it feels like it used to.
Tek310
09-28-2011 07:54 PM
ahmad89
04-23-2010 04:43 PM
shabba
09-14-2009 12:09 PM
status
06-28-2008 04:51 PM
