How to install new ECM in 1995 Honda Accord LX
Hi, I have a 1995 Honda Accord LX automatic with the 2.2L non Vtec 4 cylinder.
I got error code 14 off the dash (D4 light blinks 1 long 4 short).
I bought a used ECM from amazon and the guy will program it and update it for my car before sending it. He asked for the VIN # and the mileage.
I have the kickplate off in the passenger floor area. What is the procedure to put the new one in? Should i have the memory fuse out or the battery disconnected before i install the new one, disconnect one of them after i install, or don't disconnect at all because it will mess the new ECM up?
Thanks for any help.
Replacing the ECU for a Trans Control Unit fault may not fix the problem for two reasons: 1) the problem may not be the TCU and 2) if there's a circuit board problem, it's probably in the TCU and not the ECU.
Code 14 is "Linear (line pressure control) solenoid open or shorted.". This may be an internal trans fault and difficult/impossible to repair.
I don't have manual at office, so will have to defer a more complete response until this evening.
ok do i have to unplug the TCU if i'm not replacing it? I'm only replacing the ECU.
I guess I'll just disconnect them both anyway thanks for the advice I'll let you know how it goes.
Fixed!
I installed the ECM as instructed and no more blinking D4 and it runs great. Thanks for the help guys. I couldn't find anything online or in the manual that tells the correct procedure, so hopefully other people will find this now who have this problem.
Parkavenue
09-18-2006 07:59 PM
