how many quartz of tranny fluid do i need?
Old 03-04-2008 | 07:45 PM
jose310's Avatar
Default how many quartz of tranny fluid do i need?
well im getting my tranny rebuild and i was wondering how many quartz does it need. its a 1994 lx auto 204XXX
Old 03-04-2008 | 10:32 PM
Default RE: how many quartz of tranny fluid do i need?
I don't know if it's all the same, but for a '98 I had it was like this:
The total (dry fill)was 6.6 quarts.
Drain & fill was 2.6 quarts.
It may not be the same all years, but it'll give you an idea of how much stays behind when you driain it.
Old 03-05-2008 | 03:53 PM
19Accord97
Ask your dealership. You'll be there anyways getting the fluid.
ONLY USE HONDA TRANNY FLUID
Old 03-05-2008 | 06:02 PM
hondadude's Avatar
I think the last full rebuild I did used 7.5 quarts
Good idea to go ahead and put a quart into the TC before install, so it doesn't start up dry.
Then after the trans is bolted up and axles are in you can put in 4 quarts, thats enough to start it up, shift thru reverse and drive, holding the brake of course, then shut it off and recheck the fluid level.
02whitemaximase
10-03-2012 12:54 PM
Mott
12-04-2010 10:12 PM
wcoyote2006
11-01-2010 12:53 AM
jasonan
08-28-2009 11:26 PM
mike87
07-13-2009 10:16 AM
Quick Reply: how many quartz of tranny fluid do i need?
