How much longer can my 1997 Accord last?
I have a 1997 Accord with 150,000 miles on it. Every year (sometimes multiple times a year), I'll take it to the dealer or mechanic to have things fixed and to get an oil change. I'm on my third timing belt already.
I've had some repair guys tell me the car is in good condition, and a few years ago some guys said "This car only has 130,000 miles on it?! It's still a baby!'
Recently I had a problem with gasoline leaking from the car, and my mechanic said the whole fuel line had rusted as well as one of the brake lines. So he replaced those, but he had to order the parts from Japan because he said nobody in the US carried them anymore.
I read somewhere that if the fuel and brake lines have rusted, then the car probably won't last much longer. I do hear a little bit of squeaking if I go over speed bumps - not sure if I should be concerned about that. How much longer do you guys think my car can last?
There is no way anybody can answer that question without getting the car up on a lift and giving it a close inspection. The fact is, brake and fuel lines rusting out is pretty normal in Gen 5 and Gen 6 Accords, however, it is a definite maybe as to whether the rest of the car is in similar condition.
Plan B: If you want a fun summer vacation, drive out to Rocky Mtns and west of there. Utah, Idaho, Nevada, Oregon, etc. These states use almost no salt on winter roads (sand instead) so the cars have little body rust and you could maybe pick up a decent less rusty newer car while you're having a good time as a tourist. Have some fun ...
I live in the Mid-Atlantic where they definitely put a lot of salt on the roads when it snows.
The engine/transmission life are hard to predict. Routine maintenance helps prolong the engine life. The 94-97 engines can get over 300K miles.
The condition of your accord's body is easier to inspect for rust specifically the sub-frame and suspension components.
thunder_x
07-09-2007 02:08 PM
