how to re-re ignition igniter
Old 10-14-2009 | 06:33 PM
adrian92
Default how to re-re ignition igniter
got a 92 accord and after hours of scratching my head finally diagnosed a bad igniter. went to replace it and cant get the rotor off to access the igniter please help!!
Old 10-14-2009 | 07:01 PM
adrian92
anyone ?? please?? cant find it on the do it yourself forum!
Old 10-14-2009 | 07:16 PM
there should be one bolt that holds the rotor on the distributor shaft. Remove that bolt, and the rotor should slide off.
If the rotor is turned the wrong way, so you can't access this bolt easily, unplug the electrical connections to the distributor (there are two, I think). Then turn the key to the start position for a split second to turn the engine. You should be able to access the rotor bolt.
Old 10-14-2009 | 09:14 PM
adrian92
there is no bolt/screw on the rotor that i can see. I had my sister cranking the motor slowly but nothing there!!!!!!!
Old 10-14-2009 | 11:11 PM
adrian92
anyone feel free to chime in
Old 10-15-2009 | 11:03 AM
deserthonda's Avatar
get 2 screwdrivers and pry it out , sometimes ,it sticks pretty good ,,,been there , done that
barnfindhonda
05-20-2013 07:37 PM
blumule
03-05-2013 07:20 PM
1992ACCEX Tim
06-27-2012 09:03 PM
deserthonda
04-07-2007 06:45 PM
supa16
09-28-2006 04:56 PM
