how to remove a 3m double-sided tape?
Old 08-14-2011 | 12:05 AM
gelboy's Avatar
Default how to remove a 3m double-sided tape?
I bought an aftermarket fuel lid cover on my 09 accord. unfortunately I didnt put it right, I want to redo it again. I tried to remove it but it was so sticky. my questions are:
what tool do I need to use to remove it?
If I removed it already can I buy another 3m tap so I can stick it back again to the fuel lid?
pardon my english. this is also my first post. thanks in advance
Old 08-14-2011 | 12:17 AM
gelboy's Avatar
sorry I put this in the wrong forum. Idk how to move this to the general discussion forum
Old 08-14-2011 | 02:31 AM
Moved it for you..Welcome!
Old 08-14-2011 | 04:02 AM
engtaz's Avatar
Almost A Senior Member
Adhesive remover from auto stores or Walmart should work.
Old 08-14-2011 | 11:00 AM
bigpat's Avatar
Goof Off adhesive remover works very well.
Old 08-14-2011 | 11:45 AM
I like 3M adhesive remover which I was able to pick up at Walmart. It is in the auto section and can have a black or white label. The one I bought was a white label.
walmart.com/ip/3M-12-oz-Adhesive-Remover/17056835
Old 08-14-2011 | 01:22 PM
Then for new tape, 3m would be the brand of tape I would look for....you'll have to figure out width and thickness. Then go to a good parts store or if there is a paint store near by then go there, they should have or be able to get you what you will need.
Old 08-15-2011 | 09:15 PM
gelboy's Avatar
thanks a lot I appreciate it
justinit
09-24-2009 05:56 PM
rubenm199253
07-13-2009 09:17 AM
Sled14
10-31-2008 07:41 PM
DANIELYSE9
02-13-2008 11:33 AM
dan_o_89_rs
08-23-2007 04:14 PM
