How to replace front turn signal in '97 Accord DX
I need to replace the right front turn signal bulb in my '97 Accord DX.
The manual appears to show a screw on the right side of the cover that is supposed to provide access to the bulb. I see no such screw, or any other way to access this bulb.
Can anyone provide instructions on how I can get to this bulb?
Thanks.
Thanks.
If this is the turn signal bulb in the front bumper, then the screw is way back there, so you will need a long screwdriver.
If you go to the common diy thread on top of the gen tech help forum, there is a link to online shop manuals. You can get the 94 shop manual from the honda tech link that is pretty much identical to your 97.
You also can buy a new replacement side marker on amazon for $10 it comes with the bulbs as well in case a clip or something breaks . Its actually easier to replace the entire fixture then it is the bulb. Unfortunately I dont recall what was involved in replacing just the bulb other then it being a pain.
Turn signal is as PAhonda stated, see attached pic. from owner's manual.
Side marker and parking light has a screw up top, after you open the hood, also see attached pic.
For the record, the correct replacement is Sylvania 1156A.
The image redbull posted was a great help. Do you happen to have a link to the full manual?
1ATony
01-27-2011 03:42 PM
bilottashii
06-10-2008 12:33 PM
