how to replace ignition switch on 97 accord
I've done this on 94 EX. It's an easy job.
1) Remove upper and lower covers. I think 4, Torx-head screws (not sure of size). Covers are held together w/ some snaps, so you have to force apart after pulling screws.
2) Disconnect electrical connector to switch.
3) Remove 2 security bolts (round heads) holding switch in place. Use a sharp awl or cold-chisel to hit the bolt edge and turn the bolt head CCW. One blow each was all mine req'd. Once loose, you can turn w/ fingers.
4) Pull switch.
Reverse for installation.
4) Pull switch.
DA KID RYU
08-05-2009 06:38 AM
Mikebike125
01-18-2008 08:07 PM
